connect arduino due with factory io
after programming arduino due by grafcet studio can i simulate the program with factory i/o i need to make connection between arduino due and factory i/o
Online
Re: connect arduino due with factory io
Hello,
no, Factory I/O does not have a native driver for an Arduino Due.
Theoretically, you could connect Factory I/O to an Arduino via Modbus, OPC/UA.
However, if you have programmed the Arduino with Grafcet-Studio, it cannot be addressed via Modbus or OPC UA at the same time.
THANK YOU SIR FOR YOUR FAST ANSEWR ,SIR WHEN I USE ARDUINO IDE I CAN UPLOAD CODE WITH MODBUS TCPIP CONFIGURATION TO DEVICE SO I CAN MAKE CONNECTION BETWEEN FACTORY I/O AND ARDUINO AND SIMULATE MY CODE BUT THE QUESTIONS HERE IS HOW CAN I ADD THIS IMPORTANT CONFIGURATION WHEN I PROGRAMM MY ARDUINO WITH GRAFCET STUDIO
Online
Hello,
if the Arduino Due was programmed with Grafcet-Studio, it is not possible to add additional code.
This means that if you program the Arduino Due with Grafcet-Studio, you can unfortunately no longer connect it to Factory I/O.
